Old 20-Feb-2013, 10:44 PM   #12
elmo
Hmmm. So it's pointed in the right direction it sounds like. Any issues getting WGTV-PBS Ch 8? It's close to WXIA in distance, frequency. Can you also check the signal strengths on the TV for those?
To confirm, what antenna did you get - the HD7000R?
I wonder if someone will recommend an FM trap. I haven't used one that wasn't built into an amp, so I can't really say. But it often helps on VHF issues from what I understand. Only $5 at a Radio Shack, so worth a try, IMO.
