Old 20-Feb-2013, 8:52 PM   #6
I am doing you a disservice with the following recommendation.
However here it is.
Install a Channel Master CM4228HD antenna in the attic.
Aim the CM4228HD at about 326 degree magnetic compass direction.
Run Separate coax from the CM4228HD to the Tv.
Do not use the jointenna.
The HD7015 and CM4228HD are 2 Separate antennas systems.
And are not connected together on to 1 coax.
Use Remote control A/B antenna switch at the Tv location to change from one antenna to the other antenna.
http://www.mcmelectronics.com , #32-4425.
