Ok I tried adjusting the antenna some yesterday channel 69 seems to be comming in a bit better started to have a little pixelation on channel 17. I ordered a longer piece of coaxial so I can try raising it a little higher. Also ordered the winegard hda-100 ampilfier to give it a try. If it helps then great if not oh well guess I'm out about $40 then. I will post my results after I get done dialing everything in.
