Old 19-Feb-2013, 8:25 PM   #9
ranchersd
Success! Thanks to all that replied.
I completed my OTA project this weekend. I decided try for a single antenna solution and bought the Clear Stream 5. It is aimed at the weaker VHF channels in my market. All of the other channels I desired are coming in clear and strong and so are those weaker VHF stations. Woohoo. The antenna is mounted to my chimney and is approximately 30' in height. I sunk an eight foot grounding rod near the corner of the house. The mast and the coax grounding block are connected to the rod. Additionally, I have the grounding rod bonded to the house ground by way of ground connection for my Air Conditioning compressor conveniently located in the same corner of the house. Goodbye cable tv. Thanks again for all of the help.
ranchersd is offline   Reply With Quote
