Old 19-Feb-2013, 6:42 PM   #2
Above the roof in such a manner that reception is not blocked in all directions by the roof and house , install a Winegard HD7082P antenna aimed at about 260 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing.html.
As always , the starting aim direction of a antenna is the -->starting aim direction of a antenna.
The aim direction can then be adjusted for best reception.
Most Digital Tv's have a built in Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
__________________________
No preamplifier is required.
Do not use coax boots that go on the coax to keep water out of outside connections.
The coax boots fill up with water and keep the water inside of the boots where the water will damage the connections the boot is supposed to be protecting.
Use http://www.coaxseal.com , http://www.grainger.com/Grainger/3M-...T86?Pid=search.
________________
As always , trees and tree leaves do a good job of , reflecting , absorbing , blocking , OTA= Over The Air , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7080P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
