Thread: Setup Help
Old 18-Feb-2013, 9:45 PM   #17
BobHaskett
Originally Posted by No static at all View Post
Mileage ratings are pretty much useless when evaluating real world performance. The actual specifications are a much better parameter.
The C2V should work for you outside since the ANT751 tested well for you yesterday. The C2V is not quite as sensitive on VHF, but your weakest channels are UHF. I wouldn't recommend the C2V in the attic since the signals will be weaker & the potential for multipath interference is much higher, especially with VHF.
Is the 7694 stronger than the C2v across the board? 7694 would be the biggest antenna I would want. Really just looking for anything a bit stronger than the 751R no more than roughly a foot or two longer/wider. Much bigger than that and I think the Mrs would rather just do without.
BobHaskett is offline   Reply With Quote
