Old 18-Feb-2013, 3:21 PM   #6
Map_guy
Thanks for the reply.
I already ordered a CPA-19, ill see if that helps out. I also grabbed a win tv usb 950q tuner card so I can use a laptop to help locate the antenna. There seems to be an app that shows error received and signal strength. Maybe that will help me get to the bottom of this.
Would a 91xg be a better antenna to cut down on the multi-path?
Map_guy is offline   Reply With Quote
