Old 19-Oct-2010, 10:19 PM   #14
Tv Antennas
As part of a understanding and evaluation process , get some binoculars , drive around housing areas where houses are at , stop and look at Tv antennas on houses. Do any have a - separate - wire attached to the antenna that could be connected to a ground. . Think about what you have found out. Think clearly , has the house ever been struck by lightning , will the the house or even the Tv antenna ever be struck by lightning? Also think about this , some houses have metal roofs , are the metal roofs grounded with ground wires. Also think about this , some houses have metal siding , is the metal siding grounded with a ground wires?
