Old 17-Feb-2013, 4:03 PM   #10
nmh5028
Originally Posted by teleview View Post
My evaluation , A tangled Mess with multipul defective equipment through out the tangled mess.
Recommendation , Remove ->ALL<- of tangled mess.
Recommendation. 1 Step at a time , build a Practical and Useful reception system.
-->Repair or replace ALL defective coax and connectors.<--
For 1 Tv connected use No splitter. No amplifier.
For 2 Tv's connected use a New CM3412 distribution amplifier.
The coaxes from the CM3412 outputs will go directly the 2 Tv's , there will be no other splitters or amplifiers connected.
For 3 or 4 Tv's connected , use a New CM3414 distribution amplifier , The coaxes from the outputs of the CM3414 distribution amplifier will go out to each Tv location and there will be no other splitters or amplifiers in the coax lines that go out to each Tv location.
For more then 4 tv locations use a CM3418 distribution amplifier , the coaxes from the CM3418 distribution amplifier will go out to each Tv location and there will be no other splitters or amplifiers in the coax lines that go out to the Tv locations.
Repair or replace ALL defective Tv's , and any other defective electronic equipment.
Above the Peak of the Roof install a New Winegard HD7698P antenna aimed at about 345 degree magnetic compass direction.
I appreciate the suggestions but replacing all of my new equipment, rewiring my entire house, and buying all new TVs doesn't really fit in my schedule or budget. Also, as I mentioned in my first post, mounting on the roof is not an option.
nmh5028 is offline   Reply With Quote
