Old 17-Feb-2013, 5:04 AM   #2
A well built DIY 4-bay antenna such as the M4 (either 9 1/2" or 10" whiskers) should have little trouble with WLIW, provided the antenna is aimed at the station and not obstructed by buildings or vegetation.
I'm guessing you're in a condo or apt?
If you're facing close in obstructions, you may need to go up in size and performance... Even an Antennas Direct 91XG is not overkill if you're fighting multipath or similar transmission / propagation impairments.
For outdoor mounting, the basic antenna for the NYC market is a Winegard HD7000R or similar all channel antenna.
