Old 16-Feb-2013, 10:18 PM   #1
kaylasdaddy
Help with Antenna selection and mount location
I cut the cord. DSL on the way and other options to try soon.
I can hang an antenna in the attic (15-18 ft.) and run the cable down thru the wall to the crawl space to connect to house cables or go outside (20 ft) and run cable down the fascia and brick wall to crawl space.
What does my coverage look like? Which would give me enough good signals? There appears to be plenty available, many duplicates, but perhaps not because they appear to be all over the 360 degrees.
What do you think?
http://www.tvfool.com/?option=com_wr...1dda70e05513a5
thanks...
kaylasdaddy is offline   Reply With Quote
