Old 16-Feb-2013, 9:35 PM   #9
My evaluation , A tangled Mess with multipul defective equipment through out the tangled mess.
Recommendation , Remove ->ALL<- of tangled mess.
Recommendation. 1 Step at a time , build a Practical and Useful reception system.
-->Repair or replace ALL defective coax and connectors.<--
For 1 Tv connected use No splitter. No amplifier.
For 2 Tv's connected use a New CM3412 distribution amplifier.
The coaxes from the CM3412 outputs will go directly the 2 Tv's , there will be no other splitters or amplifiers connected.
For 3 or 4 Tv's connected , use a New CM3414 distribution amplifier , The coaxes from the outputs of the CM3414 distribution amplifier will go out to each Tv location and there will be no other splitters or amplifiers in the coax lines that go out to each Tv location.
For more then 4 tv locations use a CM3418 distribution amplifier , the coaxes from the CM3418 distribution amplifier will go out to each Tv location and there will be no other splitters or amplifiers in the coax lines that go out to the Tv locations.
Repair or replace ALL defective Tv's , and any other defective electronic equipment.
Above the Peak of the Roof install a New Winegard HD7698P antenna aimed at about 345 degree magnetic compass direction.
Here are some Strong and Sturdy Above The Roof antenna mounts.
http://www.ronard.com/909911.html , if using the tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , if using a eave antenna mount use the #4560.
http://www.ronard.com.ychim.html.
Buy the ronard antenna mounts at solidsignal by typing the word ronard ronard in the solidsignal search box or buy from ronard.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
________
As always , trees and tree leaves do a good job of , reflecting , absorbing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best install the HD7698P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Digital Tv's Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
