Old 19-Oct-2010, 9:26 PM   #11
John Candle
Tv Antennas
So I ask my self , whats with this Big Point that is being made about correctly Bonded or properly bonded ground. So I researched it up one side and down the other. It means to make a solid electrical connection that will not come lose in normal use. Can solid electrical connections be made for beyond normal use ? Yes and thats Ok also. So a ground wire that is wrapped around a ground rod , is that a solid electrical connection ? Answer: No it is not. So a ground wire that is clamped to a ground rod with a clamp that is made for this purpose , is this correct grounding ? The answer is Yes.
