Old 15-Feb-2013, 9:16 PM   #4
Above the Peak of the roof in such a manner that reception is not blocked in all directions by the roof and house , Install a Winegard HD7000R antenna aimed at about 268 degree magnetic compass direction.
http://www.ronard.com/909911.html , Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , use the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
As a Test to Prove Reception , connect a NEW loooong coax to the matching transformer (balun) that connects to the HD7000R antenna , and run the NEW loooong coax through a open door or window , Direct to the New Tv and connect to the Tv.
No couplers , No ground blocks , No splitters , No DVR's , No VCRs , No Tivo's , No cable boxes , No satellite receivers , No nothing.
It is the , Antenna , Matching transformer , Coax , Tv.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , often named the , 'Air Channels' or 'Antenna Channels' , in the Tv Setup Menu because the , OTA= Over The Air , Digital Broadcast Tv Transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Digital Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
What is reception like now??
