Old 15-Feb-2013, 8:47 PM   #3
Despite being less than 5 miles from Lookout Mountain, you may well find that those signals simply aren't available to you at your address due to being on the back side of Green Mountain.
I'd suggest calling several of the local stations and asking the engineering department if they've done surveys in your neighborhood. They probably have at some time and can give you advice as ot whether or not their signals will reach you. Most likely, channels 7 & 9 will be more readily received, but it would help if you can make a list of what has been received with other antennas in the past.
If you want to experiment, pick up a C2V-CJM from Best Buy and see what you might get.
