Thread: Setup Help
Old 15-Feb-2013, 4:01 PM   #7
I corrected it to say , north - north east.
WHTN-DT REAL channel 38 is at 54 degree magnetic compass direction.
WSMV-TV REAL channel 10 is at 12 degree magnetic compass direction.
25 degree magnetic compass direction is a in between aim direction.
As always , the starting antenna aim direction is the --> starting antenna aim direction.
The antenna can be adjusted for best reception.
Most Digital Tv's have a Signal Strength meter and some Digital Tv have a Signal Quality Meter.
I see the Low Signal Strengths of , FOX , CW , ION.
I am aware of the ongoing situation with , WMB channel 5 that is not on the air , and , WTVF Channel 5 and WTVF channel 25.
I see the 2 edge path obstructions , 2 or more hills/mountains , in the tvfool channel list.
I think about the trees that are most likely close/in the area to the house and other obstructions that are most likely close/in the area to the house.
And and the continuing reception reports from the question askers that are installing antennas.
And more , technical , practical , useful , information , that I have not listed here.
And the many years I have of installing antennas.
And I say to My Self.
Better to Go Big for this recommendation , so as to have Reliable Reception.
However as always , you are 100% Free to install any antenna and antenna system that you choose.
You are 100% Free to Test and Experiment.
There are Many , advisors , suggesters , recommenders , all across the internet and every where , that have something to say about Tv reception.
