Thread: Setup Help
Old 15-Feb-2013, 5:27 AM   #5
Originally Posted by BobHaskett View Post
Wow, that antenna is huge. Would I need to be more aggressive due to the distance, or because I need 6 rooms?
I do not have a chimney. I would really like to re-use the satellite mount if possible. Would rather not have a bunch of equipment mounted on my roof if I can avoid it. I can take a picture of my satellite mount when I get home if it helps.
The signal levels shown in your report are the deciding factor. You need the larger antenna to ensure a reliable signal at the output of the antenna. If you have a reliable signal at the antenna, the correct amplifier will then be able to drive all the rooms you want. (An amplifier is not an antenna, nor even a poor substitute for one.)
