Old 15-Feb-2013, 12:34 AM   #2
A simple reception situation , of the Digital Tv stations the , west - south west.
Antenna system A.
The , NBC , ABC , CBS , The PBS channels , FOX , MyNetwork , Me-Tv , Tuff Tv.
Above the Peak of the roof install a Winegard HD7698P antenna aimed at about 240 degree magnetic compass direction.
_____
Install a Winegard HDP-269 preamp.
_____
Buy the HFS splitters at , http://www.solidsignal.com , http://www.hollandelectronics.com.
_____________
Here are some Strong and Sturdy antenna mounts.
http://www.ronard.com/909911.html , If using the tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , If using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
______________________________
______________________________________________________________
Antenna system B.
For reception of.
To the , north east.
((The Country Network and The CW )) , along with NBC , ABC , CBS , PBS , Me-Tv.
Install a Winegard HD7082P antenna aimed at about 68 degree magnetic compass direction.
________________
________________
Antenna systems , A and B , Are Not connected together on to 1 coax.
Antenna systems A and B are SEPARATE antenna systems all the way to the Tv location/s.
At each Tv location will be a Remote control A/B antenna switch.
Remote control A/B antenna switching Is Channel Surfing Friendly , press the button on the hand held remote control , Change Antennas and Keep On Channel Surfing. http://www.mcmelectronics.com , #32-4425.
__________
The 2 antennas will be separated by about 3 feet on the same antenna mast.
The HD7082P below and the HD7698P above.
Putting 1 antenna such as the HD7082P antenna on a antenna rotator and rotating the antenna to receive the Digital Tv stations/channels to the , west - south west and north east , Is Not channel surfing friendly , must wait for antenna to rotate and Their Will Be Domestic Situations about the direction the antenna is aimed.
It is not a requirement to install both antenna systems at the same time.
You can choose your direction of reception and go with 1 antenna system.
Install the other antenna system later.
