Thread: Setup Help
Old 14-Feb-2013, 10:25 PM   #4
Above the roof in such a manner that the roof and house are not blocking reception to the , north - north east , install a Winegard HD7082P antenna with a Winegard AP8275 preamp , aimed at about 25 degree magnetic compass direction.
The Leviton 6 way splitter is not power passing , so install the AP8275 / power inserter / power supply , before the splitter input.
Here are some - Strong - and - Sturdy - roof top antenna mounts.
http://www.ronard.com/909911.html. If using the tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. If using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
_________________
As always trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Digital Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
___________
