Thread: Setup Help
Old 14-Feb-2013, 9:50 PM   #3
BobHaskett
I would be quite a bit more aggressive in my selection of an antenna. A larger all channel antenna such as the Winegard HD7084P would be my choice. I believe you'll need the added gain for both the Low-VHF and the UHF signals. Also, I would opt for a preamp with better noise performance, I'm thinking of the Antennas Direct PA-18.
A satellite J-pole is a bit small if not guyed, also, the antenna needs to be high enough to 'see' over, not through the roof. Can you chimney or gable mount?
Wow, that antenna is huge. Would I need to be more aggressive due to the distance, or because I need 6 rooms?
I do not have a chimney. I would really like to re-use the satellite mount if possible. Would rather not have a bunch of equipment mounted on my roof if I can avoid it. I can take a picture of my satellite mount when I get home if it helps.
BobHaskett is offline   Reply With Quote
