Thread: Setup Help
Old 14-Feb-2013, 8:12 PM   #2
I would be quite a bit more aggressive in my selection of an antenna. A larger all channel antenna such as the Winegard HD7084P would be my choice. I believe you'll need the added gain for both the Low-VHF and the UHF signals. Also, I would opt for a preamp with better noise performance, I'm thinking of the Antennas Direct PA-18.
A satellite J-pole is a bit small if not guyed, also, the antenna needs to be high enough to 'see' over, not through the roof. Can you chimney or gable mount?
