Old 13-Feb-2013, 4:06 AM   #8
Based on the Receivable Digital Pending Applications Included English Language Tv stations/channels.
CKMI-DT UHF channel 20 - Global.
CBMT-DT UHF channel 21 - CBC.
CKMI-DT VHF channel 11 - Global.
CFCF-DT VHF channel 12 - CTV ONE.
______________________________________________________________
Antenna system A.
I recommend for reception of.
CKMI-DT UHF channel 20 Global , aim a Channel Master CM4228HD UHF antenna at about 71 degree magnetic compass direction.
For 1 Tv connected use No splitter. No preamplifier.
For 2 Tv's connected use a Channel Master CM3412 distribution amplifier.
Antenna system B.
Install a Winegard HD7698P antenna aimed at about 237 degree magnetic compass direction.
Install a Antennas Direct CPA-19 preamp.
Antenna systems , A and B.
Are not connected together on to 1 coax.
Antenna systems , A and B , are Separate antenna systems all the way to the Tv locations.
At the Tv location/s a Remote control A/B antenna switch will be connected to the 2 Separate antenna system coaxes.
Remote control A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and keep on channel surfing.http://www.mcmelectronics.com. #32-4425.
http://www.saveandreplay.com , has the same A/B antenna switch.
Here are some places to buy antennas and HFS splitters.
http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.amazon.com , http://www.solidsignal.com , http://www.channelmasterstore.com , http://www.hollandelectronics.com.
As always trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antennas at a location that has little obstructions to no obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the , OTA= Over The Air , Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' ,in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Digital Tv setup menu and and select , 'Air Channels' / 'Antenna Channels'.
_______________________________________________________________
If you will like to receive more English language channels for Free , here is a way to do it , All of the USA PBS channels and more English language channels.
Here is a good place to start.
http://www.ftalist.com.
Saveandreplay sells FTA equipment.
