Old 12-Feb-2013, 5:24 PM   #3
Try a Clear Stream 2 Complete Vhf/Uhf antenna aimed at about 330 degree magnetic compass direction.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Remove the Reflector Screen from the CS2 Complete antenna.
The reflector screen is not the Uhf reception loops.
The reflector screen is not the metal Vhf reception rods.
The reflector screen is a screen , remove the reflector screen.
With the reflector screen removed the SC2 Complete will receive at the front and back of the antenna.
___________________________
Do not use any type or kind of preamplifier or distribution amplifier.
Because a amplifier will make the reflected Tv transmissions (multipath) from the surrounding area , stronger. Stronger multipath is not good for Digital Broadcast Tv reception.
Also , go to radio shack , and buy a FM radio filter , and install in the coax line that goes to the CS2 Complete antenna.
Strong local FM radio transmissions can interrupt Tv reception.
As always , trees and tree leaves will , reflect , reduce , block , Digital Broadcast Tv Reception and so will buildings and other obstructions including your own roof and house.
It is best to install the CS2 Complete antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel trhrough yhe Air from the transmitting antenna to the receiving antenna.
Go into the Digital Tv Setup Menu and select , 'Air Channel' / 'Antenna Channels'.
Digital Broadcast Tv tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Do a Double Channel scan.
http://www.dtv.gov/rescan.html
