You're likely dealing with a lot of multipathing since you have a lot of signal around you. The amplified omni directional antenna probably compounds that, hence the fluctuations you are seeing.
Tell us more about the directional antenna(s) you tried, mounts, locations, coax, trees, direction, etc. Where's the omni directional mounted?
