There is also a Weak signal strength , WATE-TV Real UHF channel 22 ABC at 24 degree magnetic compass direction.
I suspect the WATE 22 will be received and even so there is the WATE at 102 degree magnetic compass direction that is medium strong signal strength and I suspect it will be received even though it is on the side of the antenna.
And I suspect that WTOV 9 NBC will also be received.
As always , the starting aim direction of a antenna is the --> starting aim direction.
The antenna aim can be adjusted to find the best reception.
Most digital Tv's have a signal strength meter.
Some Digital Tv's also have a signal Quality meter.
Most Tv reception situations are a compromise due to the Tv transmitter locations.
The situation is to get the antenna up and receiving so as to see what happens.
If worse comes to worse.
Then installing a antenna rotator Is Not channel surfing friendly , must wait for antenna to rotate , and their Will Be Domestic situations about the aim direction of the antenna.
->If<- , the word is ->if<- , ->not ->is<- and ->not ->will be<-.
->If<- worse comes to worse , a second antenna can be installed for better reception of the Tv stations to the , east and west.
The second antenna will not be connected to the first antenna system.
The situation is to get the first antenna system up and operating so as to see what the next move , if any , will happen.
__________________________________________________________
As always the other advisors here at tvfool can present their recommendations for a complete and operating antenna system.
