The tvfool radar plot and channel list shows that , WVNY REAL VHF channel 13 ABC , the strongest station is only 13.1 NM(dB) , a weak signal strength.
I do not think the KT-200 will be overloaded from such a weak signal strength.
I do not recommend the KT-100 with the adjustable gain control if the KT-100 is outside , moister in the air and dirt (even if KT-100 is up under the eave) will get into the control and the operation of the unit will be erratic.
The KT-200 that does not have the separate power supply and power injector will work OK.
It is Ok to buy the KT-100 and KT-200 and Test Em.
It is interesting to test the ability of the preamps both inside and outside the house.
And then return the one that is not required.
And the HFS splitters are Very High Quality at a Very Low Price.
