Old 11-Feb-2013, 5:12 PM   #6
elmo
Well, you can always try different combinations, especially if you aren't getting the reception you'd like. Just keep in mind, the amp doesn't extend the range of the antenna, it just does a better job of bringing the signal back to your equipment. And sometimes that's a hard line to define. So the most important thing is your antenna. And speaking of, have you tried various directions? Starting at 355 is good, but be sure to try various directions around that, from say, 285 to 355. I aim a 7694 at a similar tower scenario, about 65 degrees apart. The one to the left is LOS while to the right is 1EDGE. So given that, I aim more towards the right towers and still pick up good signals from the left. If your TV has it, check the signal strengths as you tune. You may find that +5 degrees will give you a 10% gain on the weaker towers while only losing 5% on the stronger towers.
Just to confirm, you said 12.1 - that's WHYY PBS? Based on the plot, it's very weak. That has to be coming in on a repeater, right?
