There is no better antenna or preamp for your reception. You also have the right aim for the two near by groups of stations. The only way to add stations from other directions would be to aim a second antenna toward the desired stations or use a rotor. If stations you want to add are UHF only, you could mount and aim a high gain UHF yagi and another 8700 amplifier.
