Old 10-Feb-2013, 7:10 PM   #4
As often happens at hilly and mountain areas , the hills and mountains 'bend' the Tv transmissions closer to the ground. As the Tv signals cross the tops of the hills and mountains the signals are bent scatterd down ward and the earths magnetic field bends the signals down also.
The 1 foot antenna height has stronger signals then higher antenna heights.
That is good.
However trees like to , reflect , absorb , block , Tv transmissions.
So a lower antenna height usually means the trees are in the way of the stronger reception.
It is a balance act to find a location that has stronger signal strength.
In the old days it was called , Walking The Roof or Ground , holding a antenna with and without a pole to find a hot reception spot.
Usually moving the antenna up or down or to the left or right or forward or back from the current location will get a stronger signal.
Aim the HD7697P antenna at about 342 degree magnetic compass direction.
As always , the starting aim direction is the --> starting aim direction.
The antenna can be turned to the left and right to find a stronger signal.
Most Digital Tv's have a signal strength meter and some Digital Tv's have a signal Quality meter.
The Tv transmission reception is Very Weak signal strength at your location.
I recommend use a Ultra Low Noise Amplifier.
I recommend use a , http://www.kitztech.com , KT-200-Coax Tv Antenna Booster Remote Power- Coax Fed.
The remote power amplifier provides more felxibilty to install the preamp unit out of the weather.
Ultra Low Noise , antenna booster.
All electric and electronic circuits generate noise , noise has a masking effect over the signal to be received.
Less noise means more usable signal.
_________________________________________________________
WNNE and WPTZ are the same NBC , WNNE has more local news and local programing.http://en.wikipedia.org/wiki/WNNE.
WETK and WVTA are the same PBS.
http://en.wikipedia.org/wiki/WETK.
As a test of reception , the HD7697P antenna can be turned to the south at about 186 degree magnetic compass direction to test reception.
__________
Digital Broadcast Tv tuners can develop - Digital Glitches - that are not cleared out with simple channels.
Do a Double Channel scan.
When using a preamplifier that has the preamplifier unit separate from the , power supply / power injector.
And the power will be going through a splitter.
A power passing splitter must be used.
Here are some top of line power passing splitters that cost very little money.
2 way splitter. HFS-2D.
3 way splitter. HFS-3D.
4 way splitter. HFS-4D.
Buy the HFS splitters at , http://www.solidsignal.com , http://www.holladelectronics.com.
