Old 10-Feb-2013, 4:22 PM   #3
Tommymc
1 ft: http://www.tvfool.com/?option=com_wr...1ddafc9b03164e
10 ft: http://www.tvfool.com/?option=com_wr...1dda87c3dd6a61
60 ft: http://www.tvfool.com/?option=com_wr...1dda4b114d4f51
FWIW, Every spring, I spend hours in the garage boiling down maple sap. I have a homemade DB-4 type antenna upstairs in the garage hooked to an old TV to help pass the time. http://www.tvantennaplans.com/ With the antenna pointed south, I'm able to pull in WVTA ch24 (41.1) but can't get a single channel when aimed the same as my roof antenna. It might be interesting to hook the Winegard preamp up and see if it helps....since the antenna is inside, I can easily access it.
Tommymc is offline   Reply With Quote
