Old 10-Feb-2013, 3:57 PM   #6
Above the Peak of the roof install a Winegard HD7694P antenna aimed at about 0 degree magnetic compass direction.
http://www.ronard.com/909911.html , if installing the tripod antenna mount install the 5 foot antenna mount.
http://www.ronard.com/34424560.html , if installing the eave antenna mount install the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsigmal search box or buy from ronard.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winrgarddirect.com , http://www.channelmasterstore.com.
Install a Channel Master CM3414 distribution amplifier in the wiring panel.
Put a 75 ohm terminator cap on the unused output of the 4 way CM3414 distribution amplifier.
________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7694P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions including your own roof and house.
At your location the Digital Broadcast Tv transmitters are , north/north east , north west , south west.
The Tv's Must Channel Scan for the OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
