Thanks for all the great information. i am not looking to receive both markets, my preference is to get the NY stations however knowing there is a small mountain range between my location and a direct line of sight to NY I am concerned that I'll be able to receive the stations which is why if I do not I would try to point towards Philadelphia to see if I could get those stations. Really hoping NY comes in though.
Is there any concern with the lengthy runs of cable? Will the pre amp provide the signal strength needed knowing there would be about a 40 foot run before the splitter and then a 40 foot after the split to one of the rooms? This particular run would be for the master bedroom and the TV is used extensively. Just want to make sure that run will have the signal strength needed to be able to pull in the stations.
Thanks!
