Old 10-Feb-2013, 12:02 AM   #5
For reception of the Canada Digital Tv stations/channels.
Aim a Winegard HD7696P antenna at about 305 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing,html.
Looking at the Strong Signal Strengths of the USA Digital Tv stations/channels in the Green reception zone of the tvfool Pending applications Included channel list.
I am - Confident - that All the USA Digital Tv stations/channels in the Green reception will be Received Reliably , without rotating the antenna.
The HD7696P antenna Must Be installed above the roof in such a manner that reception Is Not Blocked by the roof and house in the directions of reception , north west , west , south west , south , south east , east.
As always , the starting aim direction of a antenna is the --> starting aim direction of a antenna.
The antenna aim can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter , and some Digital Tv's also have a signal Quality Meter.
The HD7696P antenna will receive the Canada and USA Tv stations/channels at both houses.
_________________________________
The Digital Tv transmissions are a little stronger at the second house.
Use a Winegard HDP-269 preamp.
Buy the HFS splitters at http://www.solidsignal.com or http://www.hollandelectronics.com.
________________
http://www.ronard.cm/909911.html , if using the tripod roof antenna mount , use the 5 foot antenna mount.
http://www.ronard.com/34424560.html , if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
As always , trees and tree leaves do a good job of , reducing , reflecting , blocking , DogitalBroadcast Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select 'Air Channels' / 'Antenna Channels'.
