Old 9-Feb-2013, 8:20 PM   #2
If we were neighbors, you'd see a larger antenna on my roof. Likely a Winegard HD7696P pointed south. If I could find a new Antennas Direct CPA-19 preamp, that would be on the mast, just below the antenna. I would be able to drive 100' of RG-6 and the losses of a 4-way splitter easily. If I needed to drive more tuners, I would replace the passive splitter at the distribution point (assumed to be 50 feet or more from the preamp) with a Channel Master CM-3418 distribution amplifier.
You could opt to go another way all together... An RCA ANT-751R. Experiment with the aim point starting from 333°.
