Thread: sixty mile help
Old 9-Feb-2013, 6:26 PM   #5
No static at all
No static at all's Avatar
CBS in on VHF so a different antenna will be needed as the C4 is designed primarily for UHF. CBS is on the weak side at your location, so I would recommend either augmenting your present antenna with either this or this. You could also start over from scratch with a combo UHF/VHF antenna, but it would have to be rather large to match the UHF performance of what you are already using.
