I installed the CM3410 today prior to the first 2-way splitter and then reconnected my second 2-way splitter. I installed a new power outlet in the attic crawlspace and managed not to electrocute myself or catch anything on fire. That was obviously the hardest part about installing it and it wasn't really that difficult.
Results! The short run is still working just fine. On the longer runs, I saw a significant improvement in all channels, but 9 is still giving me trouble. All the other channels are in the 60-80% range now, but 9 is still in the 40's. It's not cutting out anywhere near as much as it was before at least, but it's still not what I would consider watchable or reliable.
I'm wondering if simply elevating my antenna might improve the reception. I could move it up a couple more feet, but I don't know how much it would really help. Again, any input would be appreciated. Should I consider a distribution amp in place of the second 2-way or would it just produce too much noise?
