Old 9-Feb-2013, 2:27 PM   #3
Stereocraig
Originally Posted by boydzz View Post
Hello all,
This site has been a great resource as our family has decided to drop cable TV. I'm in need of some antenna guidance and location help. Here goes:
Here's my Signal Analysis Results:
http://www.tvfool.com/?option=com_wr...1dda10c9016d63
I'm trying to get the following channels by priority:
1) WOOD-DT (7)
2) WGVU-TV (11)
3) WZZM (13)
4) WXMI (19)
5) WWMt (8)
I have three mounting options with clear views to the South-east. In order of easiest to hardest effort required to mount:
1) In garage attic (~13-15 feet off the ground)
2) in second Story attic (~25 feet off the ground)
3) attached to top of chimney (~30 feet off the ground)
Its the dead of winter here, so regardless the first place I will likely mount is in the garage attic.
I will need to run ~75 feet of co-ax to get the antenna feed into my house for options 1 & 2. Considerably less for option 3.
I plan to split the signal one-time once inside the house to feed two tv's
I am looking for advice on ideal antenna and mounting locations.
I appreciate the feedback.
Tim
If you ever care to add another antenna, it looks like you have a clear shot at Milwaukee, too.
I see their channels on your list, just not on the radar.
