Old 9-Feb-2013, 7:25 AM   #2
Above the Peak of the roof install a Winegard HD7696P antenna with a Winegard HDP-269 preamp in such a manner that the reception is not blocked by the roof and house in the directions of , north east , east , south east , south.
Aim the HD7696P antenna at about 170 degree magnetic compass direction.
________________________
http://www.ronard.com/909911.html , if using a tripod antenna mount use a 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , if using a eave antenna mount use the #4560.
http://www.ronard.com/ychim.html , http://www.ronard.com.
__________________________
______________
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
__________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , OTA=Over The Air , Digital Broadcast Tv stations/channels reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
____________
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
