Old 8-Feb-2013, 2:10 PM   #18
If you will like to use a Bigger Antenna.
Then use the Strong and Sturdy and Heavy Duty , Long Lasting , Winegard HD7082P antenna.
If you choose to install the HD7082P antenna , Do Not use the DS3000 J pole antenna mount , it is not enough mount to hold the HD7082P antenna.
Use one of the ronard antenna mounts I have listed.
