Old 8-Feb-2013, 4:58 AM   #9
Chaining splitters is not the best way to do wiring , to much signal losses and signal reflections in the system causes problems , pixalation , signal flucuations .
For your reception situation I recommend move the CS2V antenna to above the roof so reception is not blocked to the , north west , west , south east.
To receive the following Digital Tv Channels with a Stronger signal and --> more important --> better Signal Quality.
The Digital Broadcast Tv tuners in Tivo's , take a very dim view of poor signal quality. With the antenna in the attic.
The better the signal Quality is , the better the Tivo's will display a nice steady picture. With the antenna above the roof.
WCTI ABC , Live Well Network , This Tv.
WITN NBC , MyNetwork , Me-Tv.
WNCT PBS.
WUNK PBS.
WYDO FOX.
WEPX ION , Qubo , ION Life.
WFXI FOX.
___________
((((The best way to do coax wiring is have - 1 splitter - that all the separate coaxes is connected to and no other splitters.))))
If you will not do the above 1 splitter recommendation , then.
I recommend do the system like this.
Coax from the Antenna above the roof to the 2 way splitter.
One output of the splitter goes the short distance to the Tv.
Connect a Channel Master CM3410 distribution amplifier to the other output of the 2 way splitter close to the 2 way splitter.
The output of the CM3410 distribution amplifier is connected to the coax that goes out to the location of the 4 way splitter.
At the location of the 4 way splitter , only have a splitter with the required outputs.
If 2 Tv's are connected , use a 2 way splitter.
If 3 Tvs' are connected , use a 3 way splitter.
If 4 Tv's are connected , use a 4 way splitter.
Using the correct splitter with no unused ports will reduce signal reflections in the system.
The cleaner the signal , the better the Signal Quality.
The cleaner the signal quality , the Happier the Tivo's will be.
The Happier the Tivo's are , the Happier You Will Be.
___________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Broadcast Tv reception , and reducing signal quality and so do attics , roofs and houses , including your own roof and house.
It is best the install the CS2V antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
Here are some Strong and Sturdy antenna mounts ,
http://www.ronard.com/909911.html , if using a tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts by typing the word ronard in the , http://www.solidsignal.com , search box or buy from ronard.
The CS2V is a Small , Light Weight , Strong and Sturdy , antenna.
