If I were in your shoes, I would replace the first splitter with the CM 3412. You could also use it to replace the 2nd splitter, but IMO the 1st scenario should provide the best results.
With either scenario I can't imagine you will overload any of your tuners. I have slammed these things with much stronger signal levels & have always had excellent results.
Reason: typo
