I doubt the first TV will have trouble. But if it does, use the CM-3410 and move it to just after the output of the first splitter, this will leave the first TV/converter with an unamplified feed, and still provide amplification ahead of the cable and splitter losses that feed the TiVo's.
Another way of saying this is, use a separate amp and splitter to maintain maximum flexibility if you need to add to or change the system.
TiVo tuners seem to have a less than stellar reputation as far as OTA performance is concerned. Consider testing reception with the C2 outside and connected directly to one TiVo, then the converter... I suspect you can easily find higher quality signal outside, clear of the attic impairments.
