Old 7-Feb-2013, 8:37 PM   #4
If you are going into the attic for sure, err on the side of caution by measuring for how long and wide you can accommodate.
I would consider an Antennacraft C490 if it will fit. You may need the additional gain due to losses caused by roof construction. The antenna needs to be placed so it can point ESE while not pointing into duct work or other metal. It needs to be at least 3' from metal to the sides.
If re-using satellite cable, be sure to remove any and all parts that are designed to pass only satellite frequencies. The splitter can be mistaken for a diplexer and vice versa.
