Old 7-Feb-2013, 4:12 PM   #1
d4manek
Need Antenna Suggestions
Here is my signal analysis report:
http://www.tvfool.com/?option=com_wr...1dda7365cf3c40
I am currently able to pull in all stations I want (ABC, CBS, FOX, ION, NBC & PBS) using a simple antenna like this one when placed next to a southeast facing window.
My goal is to place an antenna in one of two places. Ideally, I would like to place an antenna in our attic so it is out of site. Our house backs to open space so there are no obstructions. In this scenario, I don't care what the antenna looks like.
The second place I could put the antenna is where our current satellite dish is installed (outside), which is on the south corner of our house and about 10 feet above the ground. Again, there are no obstructions, but the antenna would be visible so I would prefer something that looks good (e.g., a simple looking antenna or one of those flat/enclosed antennas).
Our house if fairly large. It is about 50 feet from the attic to the central wiring location where I need to distribute the signal. If the antenna is placed outside, then it will be about 100 feet to the central wiring location. From the central location, I will feed 3 TV's which are approximately 10 feet, 50 feet and 100 feet away.
Looking for antenna, amps and distribution equipment suggestions. Thanks in advance!
d4manek is offline   Reply With Quote
