Old 7-Feb-2013, 2:49 AM   #7
No static at all
No static at all's Avatar
here's a couple of tips:
1. Loose the amplifier.
2. Run by Radio Shack and pick up a 15-0024 FM filter. Keep your receipt, just in case. Install install the filter in your down lead.
3. Aim your antenna at La Jolla and see what happens. Try different heights moving the antenna up and down a foot at a time.
Excellent suggestions for a next diagnosis step!!
You simply CANNOT use any preamp in your situation. The weak VHF stations can easily be trampled by the strong 2nd harmonics of 2, maybe even 3 local FM signals. Trying the FM filter is a good idea also. You may even need something stronger, but this is an easy way to test with something available locally.
If amplification is truly needed, I recommend the Channel Master 3414 which is extremely tolerant of blistering VHF & UHF signals & will deliver an even, robust signal up to 4 splits with minimal dynamic range compression.
