here's a couple of tips:
1. Loose the amplifier.
2. Run by Radio Shack and pick up a 15-0024 FM filter. Keep your receipt, just in case. Install install the filter in your down lead.
3. Aim your antenna at La Jolla and see what happens. Try different heights moving the antenna up and down a foot at a time.
If that doesn't pan out, you might need a San Diego Special: A high VHF antenna pointed at La Jolla and a separate bidirectional UHF antenna to catch both Tijuana and San Miguel signals at the same time. Before I went that route, though, I suggest a ClearStream 5 aimed at that direction. You'd likely be successful with that one antenna.
