Old 5-Feb-2013, 9:54 PM   #2
A Simple reception situation.
The OTA=Over The Air , Digital Broadcast Tv transmissions are Very Strong Signal Strength at your location.
Many , many , many , many , many , many , many , OTA=OverThe Air , Digital , Broadcast Tv stations/channels will be received.
Above the roof instal a Winegard HD7082P antenna (with No preamplifier and No distribution amplifier) aimed at about , 260 degree magnetic compass direction.
http://www.ronard.com/909911.html , If using a tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , If using the eave antenna mount then use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
_________________________________________________
For 3 Tv's connected use a simple common 3 way splitter.
_______________________________________________________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , Air Channels' / 'Antenna Channels'.
