Old 5-Feb-2013, 8:59 PM   #7
With the HD7084P antenna installed and aimed at about 162 degree magnetic compass direction.
You are -->Very Close<-- to being -->Maxed Out<- for Digital Tv Stations reception.
As always , Antenna rotators -->Are Not<-->channel surfing friendly , Must Wait for antenna to rotate and there -->Will Be Domestic Situations concerning the direction the antenna is aimed.
There are some -->Very Weak Signal Strength<-- Digital Tv stations channels in the direction of , west / south west , at about 260 degree magnetic compass direction , that the tvfool channel list is showing. And these Digital Tv stations/channels also have , Adjacent Channel Interference and Co-Channel interference issues.
As a -->Test<-- , I recommend turn the HD7084P antenna by hand to the , south west , west direction and scan for Digital Broadcast Tv Channels.
To see what is received.
You will then decide if it is enough reception to install a Completely Separate Antenna System of a Winegard HD7698P antenna and HDP-269 preamp , Separate splitters Separate coax , Separate All the way to each Tv location.
And a Remote control A/B antenna switch will be installed at each Tv location to change antennas.
Remote control A/B antenna switching is , Yes , Channel Surfing Friendly.
Press the button on the hand held remote control , Change Antennas and Keep On Channel Surfing.
http://www.mcmelectronics.com . #32-4425.
