televiews suggestion is also quite valid, so I don't wish to discredit it. I would like to point out the differences in performance so you can decide for your self.
The forward beam of the HD7696P in the UHF band is limited to less than 50° at frequencies above CH-15 or 16.
When adjusted correctly, the DB8e can have a forward beam of 90° or more.
That said, the HD7696P would be a rock solid solution for reception of the signals 20° either side of it's aim point.
Perhaps ADTech will weigh in on this one...?
