The satellite dish is aimed up at the sky , 22,000 miles above the equator at the satellites.
The satellite dishes are always installed at a location that has nothing blocking the view of the satellites above the equator.
As long as there is a unobstructed view of the satellites above the equator , the dish can even be mounted just above the ground.
_______________________
Broadcast Tv antennas are aimed at transmitter towers that are installed on the ground or on buildings , so the Broadcast Tv antenna is not aimed up at the sky above the equator.
The Broadcast Tv antenna is aimed at the transmitting tower.
